Derby cover. Gasket or o-ring?
Old 06-08-2012, 11:17 PM
Gunslingertom's Avatar
Gunslingertom
Gunslingertom is offline
Originally Posted by Uncle G.
Damn, Mine only has an o-ring, and has never leaked a drop unless I happen to pinch the o-ring putting on the cover. Why in the name of *** would you use BOTH a gasket and an o-ring? What am I missing here?
O-ring only here too. No leaks either. Have had in off and on several times.
Old 09-26-2012, 09:13 PM
caleb895's Avatar
caleb895
caleb895 is offline
What about the inspection cover gasket? I'm about to svc and adjust my primary.....I plan to re-use the o-ring on the derby cover. Do I need to order the inspection cover gasket before I start? It's a 92 FLHTC......top illustration, #30
I know the pic Isn't necessary but I happened to be looking the part up and thought this could come in handy for someone.
If you've not used the OEM parts finder before....this is a killer way to locate parts!!
Old 09-26-2012, 09:22 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,703 Likes on 1,988 Posts
Over the years, the inspection cover gasket has changed. Originally, they were cardboard with a layer of rubber printed on them. Nowdays, they are a thin piece of steel coated with rubber on both sides. I usually can reuse the new style three or four times if I have to, but it won't hurt to have one on hand. They're not that expensive.
Old 09-27-2012, 01:25 AM
lieutenant G's Avatar
lieutenant G
lieutenant G is offline
Originally Posted by Bleachey
Mine has both. There is the o-ring around the actual derby cover, then the gasket that covers the entire hole and has one side that says :this side towards clutch". Ironically the first time I removed it I was missing the gasket as well.
same here , and when the indy removed the gasket, it leaked everywhere
bellmnbell
12-08-2016 04:07 PM
89FLHTC
EVO
15
11-19-2015 08:38 AM
ridgeback
01-04-2014 03:32 AM
OkieRoadWarrior66
07-25-2010 06:28 PM
MetallicaMatt
05-31-2007 05:48 PM
Quick Reply: Derby cover. Gasket or o-ring?
