Electraglide 91 drain plug.
04-18-2012, 02:08 PM
Greetings!
Where is the engine oil drain plug(s) on EG 1991? Can not find any instructions at the Internet.
Thank you.
04-18-2012, 08:14 PM
At the bottom of the oil tank under the right side cover.
04-18-2012, 10:47 PM
Quote:
Originally Posted by
dc1450
Yup.....pull the bag and the cover, just above the bottom mounting bolt.
04-19-2012, 01:46 AM
Thank you!
So It`s 2 drain points: 1. Bottom the oil tank. 2. The oil filter (the lowest point).
Correct?
04-19-2012, 04:07 AM
The oil filter won't drain much, the Harley engine is a dry sump, but yes, that's all you need to pull.
04-19-2012, 04:59 AM
I remove the filter first. A big screwdriver and hammer is the easiest way to get that off I find! Then drain the tank and I use the cardboard tube from a large paper roll as a disposable funnel (from kitchen tissue) to direct the oil and plug into a bowl. Fit new filter, refill tank, run engine to confirm oil is circulating, then top up.
thedonthere
03-26-2019 09:47 PM
Passing Lane
Oil Archive (no new posts)
10-18-2016 09:35 AM
harleychick6567
EVO
06-22-2012 07:37 AM
vonzip
10-02-2009 06:13 PM
rivercityslim
EVO
08-30-2007 01:05 AM
01 ,
1990 ,
91 ,
copper ,
davidson ,
drain ,
electra ,
eng ,
evo ,
glide ,
harley ,
location ,
oil ,
pictures ,
plug ,
primary
