98 fatboy 1340 misfire need suggestions.
Old 05-02-2012, 06:43 PM
Sparky2411's Avatar
Sparky2411
Sparky2411 is offline
Stage III
Default 98 fatboy 1340 misfire need suggestions.
Hi I just picked up my first Harley it's a 98 fatboy with a 1340cc motor it is piped and what not but it runs rough. When I put a timing gun on the rear cylinder I get a misfire every maybe 5 to 10 fires the front misfires every maybe 1 out of every 20 time it's much better but when I hit the throttle it sputters hard misses allot on the rear cylinder but will eventually pick itself back up and wind out. I'm not new to bikes or motors but Iam to Harley's do I was wondering if someone might be able to help out with a few places I should start looking. Thanks
Old 05-02-2012, 07:38 PM
gsxrboy96's Avatar
gsxrboy96
gsxrboy96 is offline
Clean the carb and throw a new set of plugs in it, should straighten right out !.
Old 05-02-2012, 09:41 PM
Gunslingertom's Avatar
Gunslingertom
Gunslingertom is offline
Yup, start with the cheapest possibilities first.
Old 05-02-2012, 09:48 PM
FlamedFXR's Avatar
FlamedFXR
FlamedFXR is online now
Received 1,511 Likes on 645 Posts
Youve got a bad wire in the ignition pickup. The clue is that it will clear up and wind out.
Old 05-03-2012, 06:29 AM
miacycles's Avatar
miacycles
miacycles is offline
Do the plugs and wires first then work your way back through the ignition. Also because you just got this, a compression and leak down test for a baseline wouldn't hurt. Maybe some carb cleaner in the gas along with some good high test from a station that has three hoses, one for each grade. Hope this helps
Old 05-03-2012, 07:17 AM
Sparky2411's Avatar
Sparky2411
Stage III
Wires are brand new 8.8mm. Were is the ignition pickup ?
Old 05-03-2012, 09:45 AM
miacycles's Avatar
miacycles
Ignition pickup is in the nosecone, right side of engine. Double check to ensure the plug wires are all the way in, we get several customers a year that have a missfire problem because the wires aren't all the way in. Are you using a silicone grease on the plug wire ends. Also do you know what ignition do you have??
Old 05-03-2012, 04:09 PM
RidemyEVO's Avatar
RidemyEVO
RidemyEVO is offline
Take a good look at the pickup wires where they come out of the nose cone and follow where they route upto the coil and module.
Old 05-03-2012, 04:46 PM
Sparky2411's Avatar
Sparky2411
Stage III
There's a screamin eagle ignition control module other than that I don't know anything else off hand
troygalloway
06-11-2016 09:31 PM
LynneTomTom
10-15-2012 12:48 PM
77sporty
06-03-2011 10:48 PM
Big Rich 01
08-23-2009 08:23 PM
jentony20
07-31-2009 04:49 PM
Quick Reply: 98 fatboy 1340 misfire need suggestions.
