1997 Road King Fuel gauge Cap Help
Old 05-23-2012, 09:00 PM
Broncobilly72's Avatar
Broncobilly72
Broncobilly72 is offline
Default 1997 Road King Fuel gauge Cap Help
All,
I am trying to figure out how to fix the fuel gauge cap, on my 97 Road King. I bought the bike about a month back, from the second owner. The gauge works, but the cap is in the vertical position, instead of horizontal (clear portion, which you can read the gas level through).
I was told by the second guy, whom I bought the bike from, that the original owner was an old school biker. He was use to the old fat bob tanks, which you filled on the left side, then went to the right side filler. By habit, he tried to unscrew the left side fuel gauge cap - thus my problem with a cap I can hardly read, because the clear viewing portion runs vertical, instead of horizontal.
I tried rotating the cap by hand (after removing gauge from bike), so the cap viewer is aligned horizontally with the fuel/empty reading, but no dice, the cap will not budge. I hate to check with Harley on the price of the gauge, it mostly likely will be expensive!!!!!!!!!!! Any help is appreciated!
Old 05-23-2012, 09:07 PM
styndryinwa's Avatar
styndryinwa
styndryinwa is offline
not sure what you mean by seeing it sideways you can do it this way like I did no gauge go by miles instead
Old 05-23-2012, 09:17 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Try rotating the cap with the gauge in the tank....that's how it was when it got munted.
Damn things tell lies anyways...
Old 05-23-2012, 09:27 PM
Desmos's Avatar
Desmos
Desmos is offline
6th Gear
I think what op is getting at is the portion of the gauge that contains the clear lens has turned 90 degrees relative to the needle and gauge marks(fuel level delineations). I went out and looked at mine to see if it looked like you can turn it back. I think everything would have to be perfect in order to turn the thing. Maybe if it is warm enough, to sort of simulate the conditions that allowed it to slip in the first place. Just a thought.
Old 05-23-2012, 10:20 PM
Broncobilly72
Desmos, correct - that's exactly what I mean! Re-reading my posting, I wasn't too clear in my description. Anyway; if the gauge isn't too accurate to begin with, I think I will just fit a regular cap, or pop up cap - if that's possible? Anyway, thanks all for the input! I'll be darn if I can get the clear leans portion rotated by hand, to the right position.
jakedietz
06-21-2017 05:20 PM
R.Canales
2014-2023 Touring Models
05-09-2016 07:55 PM
Vinsil
07-03-2012 10:13 AM
blarg
12-08-2011 02:12 PM
btefft
03-02-2008 04:31 PM
Quick Reply: 1997 Road King Fuel gauge Cap Help
