Starter gears grinding?
ok so after going into further examination, i pulled the primary cover and watched the jackshaft as i engaged the start and it is just a ridiculous grind, not normal, and its just continuing grinding, when i take the pinion drive off the grinding goes away. when its on and engages it just grinds the hell out of it.
http://www.youtube.com/watch?v=WkZiK...ature=youtu.be
Some people gear down their starters, especially if they fitted a big bore or stroker kit and hot cams.
If your coupling is a smaller diameter than the hole it fits into then either the coupling has been changed or the coupling bushing is missing from the inner primary.
yea the coupling has been changed bc it wobble all around the primary, the options im thinking are a new coupling bushing, which would have to be figured out for that coupling size and primary hole, or a new coupling, but i couldnt use a new coupling because of the pinion drive size.
so my question is, should i just order a new starter gear since i already have the stock jackshaft assembly, plus my starter gear and jackshaft are pretty much destroyed (i.e. chipped teeth)
will the stock starter gear still work on my bike is the question
yea its missing teeth, since i already have the new jackshaft assembly im wondering if i could pick up a stock clutch basket and maybe all the discs would fit in that one?
because the starter gear is destroyed too, will 89 fit this one? if im not mistaken 90 was the different year. Looks like i might be hitting up a couple shops this weekend and see if anyone has one lying around
