Running a Cylinder Down When Hot
Here's the pertinent info:
94 FXRP with 72K. Daytona Twin Tec Ignition 1007 external. Power Arc Single fire coil.
I'm riding home today, about 20 miles on the slab. Air temperature was around 100. Suddenly I lose power and limp off an exit. I pull over and determine that the front cylinder isn't firing. Let it cool down about 10 minutes, and it starts and idles fine, but as soon as I put a load on it, the front cylinder drops again.
Trailer home, and when I get here, it starts and runs around the block just fine. Put a meter on the coil, and it reads 5.6 ohms on each of the two primary circuits (testing front and rear each to the center). I couldn't find specs on this particular coil, but I think it's supposed to be a max of 3 ohms.... right?
Since I'm only dropping one cylinder, I'm ruling out the pickup in the nosecone.... Seems if that were failing, it would quit altogether, correct? My plan is to pick up a coil, new wires, and plugs (just because). What do all you gurus think?
Thanks in advance. Heading to Sturgis next weekend, and having a broken bike there would suck pretty hard. I'd drink a lot more though.... ;-)
neverdown
08-08-2012 07:45 PM
