Starter motor not engaging.
10-08-2012, 05:23 PM
Well, I guess I have another problem. Wanted to take a short ride tonight and the starter spins but is not engaging the engine.
Manual says jackshaft or ring gear.
Battery is showing 12.8 volts without bike running.
Geeze........Where should I start?
10-08-2012, 05:29 PM
Sounds like the starter clutch gave up the ghost...
10-08-2012, 05:33 PM
If it were me, I'd try to jump start it from a non running automobile.
10-08-2012, 05:40 PM
Starter clutch, is there any grinding noises, or just spinning????
John
10-08-2012, 05:47 PM
Starter drive (clutch) is a common replacement item. It's a relatively EZ fix. If it spins and doesn't engage and the battery is showing 12.8 volts, you've pretty much already diagnosed it.
10-08-2012, 06:03 PM
Quote:
Originally Posted by
miacycles
John
Just spinning.
10-08-2012, 06:07 PM
Do the clutches go out slowly or all at once or both? I've been having intermittent starter problems for a while.
10-08-2012, 06:39 PM
Where would you guys buy this part? I found one for 80 bucks and one for 265 bucks.
10-09-2012, 05:56 AM
Hey, any answers for the questions above?
10-09-2012, 06:35 AM
If you have a stock starter I would go and buy the clutch from the dealer.
