Head bolt torque
Old 10-28-2012, 10:52 AM
95 Ultra's Avatar
95 Ultra
95 Ultra is offline
Default Head bolt torque
I'm replacing the head gasket on the front cylinder. If I'm reading my harley shop manual correctly, it says to tighten the four bolts sequentially to12-14 ft. lbs each, then turn a quarter turn and you're done. Does this sound correct? Also, I noticed the shop manual calls for o rings over the cylinder head dowels, for correct alignment of the head gasket. When I removed the head this morning, there were no o rings on the dowels. My bike is a '95 and my shop manual is for 95-96. Should there be o rings on the alignment dowels for a '95?? Thanks.
Old 10-28-2012, 02:52 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is online now
Received 2,695 Likes on 1,341 Posts
Torque description is correct. Some people/gasket makers say to not do it that way, but to torque to something like 46 ft lbs, off the top of my head, but when I did it that way, bad things happened and I had to retorque to the way the book says, 16 ft lbs +90 degrees.
Dunno about your O rings. Wouldn't hurt to put them on if they are not there now.
Old 10-28-2012, 03:02 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
You can tell if you need O rings because they fit in the holes in the gaskets, 95/96 should have O rings.
Old 10-28-2012, 07:42 PM
Owtlaw's Avatar
Owtlaw
Owtlaw is offline
A friend of mine went through this last summer on his 92. His old gaskets used the O rings, and the new ones he bought at the dealer did not. He was told the updated gaskets did not use O rings. He left them off and hasn't had an issue.
Old 10-28-2012, 10:09 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
I'm hoping this is true as this is what I did and it is what I have read about the newer aftermarket gaskets.
Old 10-29-2012, 01:58 AM
Spanners39's Avatar
Spanners39
You will soon tell because the O rings simply wont fit....
Old 10-29-2012, 11:33 AM
Bullys FLSTN's Avatar
Bullys FLSTN
Bullys FLSTN is offline
i went with the Comtic layered head gasket when i did my top end and it does not have the o-rings. And go with the torque specs in the book for the head bolts. i torqued mine to the 14ft pds and then a 90 degree turn. No problems no issues. Just make sure you lube the threads with oil or you won't get the true torque that is needed to seal the heads.
Gordie. (10-07-2020)
Old 10-29-2012, 08:04 PM
95 Ultra's Avatar
95 Ultra
95 Ultra is offline
Thanks for all the info guys!
Old 11-01-2012, 12:08 AM
Pinetop's Avatar
Pinetop
Pinetop is offline
when you torque the 1/4 turn it will torque at 48ft/lbs., but do it as the manual instructions as I have twice recently with no leaks or problems. I also put loctite red/perm. to insure no back off. My James top end gasket set came with O-rings and head gaskets. Perfect fit.
PINETOP
ScottinAZ
Engine Mechanical Topics
07-20-2019 04:32 PM
are6rider
06-23-2019 08:12 AM
Redbeard69
EVO
10-20-2013 07:32 PM
95 Ultra
EVO
11-05-2012 08:57 PM
brwdarr
EVO
02-24-2010 07:45 AM
Quick Reply: Head bolt torque
