oil routing
Old 11-12-2012, 09:36 AM
jsbridgew's Avatar
jsbridgew
jsbridgew is offline
Default oil routing
so yes, i took my lines off to do some work on bike and like an idiot i didn't take pictures
...here's the diagram....what escapes me is the 'oil tank vent' line and the 'return from filter' line
i know the diagram is a terrible picture, but maybe someone can help me understand what rubber line goes to which nipple on the tank.... even in the diagram it doesn't seem to be clear
i'm guessing that the rubber 'return from filter' line goes to the nipple on the tank that reaches highest in the tank in the diagram (the steel line that bends at a 30 degree angle at the top)?
Old 11-12-2012, 03:02 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,497 Likes on 4,612 Posts
On my `89, the oil return hose goes to the outboard nipple on the tank.
Vent to the inboard nipple.
Old 11-12-2012, 07:11 PM
1skrewsloose's Avatar
1skrewsloose
1skrewsloose is offline
Must be plenty out there to look at. Local indy could help out. We've all made similar mistakes.
Old 11-12-2012, 07:32 PM
113fatboy's Avatar
113fatboy
113fatboy is offline
The outside is for return from filter. The middle is for vent. The inside is for oil pump feed
Thats the routing on my 98 softail
Old 11-12-2012, 08:54 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is online now
Received 18,200 Likes on 5,396 Posts
Old 11-13-2012, 05:58 AM
jsbridgew's Avatar
jsbridgew
thanks guys!....very much appreciated!
and Tom, that has to be the single best diagram i've ever seen for our early evos!
Old 11-13-2012, 06:45 AM
Tom84FXST's Avatar
Tom84FXST
FYI...you constantly hear people say to run your oil level below the full mark, to reduce oil usage or keep it from puking out the vent....that is because they have the return and vent hooked up backwards...hooked up correctly you can run over the full mark with no ill effects.
Old 11-13-2012, 08:31 AM
jsbridgew's Avatar
jsbridgew
thanks so much, Tom... i've been running WAY below the fill mark and i think it did some damage....maybe you can offer some thoughts....gonna start a new thread with pics and explanation
Old 12-15-2012, 02:00 PM
toby can's Avatar
toby can
toby can is offline
1st Gear
does any body has an drawing on oil system for HD dyna mod.2000
Old 12-15-2012, 02:13 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Which particular elements are you interested in? Line routing or internal passages?
Kerr8005
Ironhead
11-07-2018 09:46 PM
infoams1
Oil Archive (no new posts)
01-02-2011 01:34 PM
jbwftx
Exhaust System Topics
12-28-2009 11:18 AM
lowglide88
EVO
04-23-2009 08:21 AM
57ironhead
Ironhead
08-09-2007 01:18 PM
Quick Reply: oil routing
