Oil pouring from crankcase breather.help!
Old 04-13-2013, 03:23 PM
mdanehart's Avatar
mdanehart
mdanehart is offline
Default Oil pouring from crankcase breather.help!
This is a drag!
Engine rebuilt and runs strong on my 1987 FLHTC. Pulled in my driveway a short time ago and a trail of oil behind me. I placed a drain pan under the breather line and oil Pours out the crankcase breather via KN breather filter.
The oil tank is almost empty, each time I start it up thirty seconds later its puking again!
By the way it's a Sifton oil pump. Any advice from the Pros?
Thanks
Mark
Old 04-13-2013, 03:29 PM
mdanehart's Avatar
mdanehart
Sa short video if I uploaded correctly.
Invalid file?
Old 04-13-2013, 04:50 PM
bluharley's Avatar
bluharley
bluharley is offline
Breather timing?
Old 04-13-2013, 05:03 PM
machinehed's Avatar
machinehed
machinehed is offline
Default oil puking.
Originally Posted by mdanehart
This is a drag!
Thanks
Mark
Ditto blueharley , or possibly mismatched oil lines.?
Has it done this only after the rebuild ???
Old 04-13-2013, 05:44 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,194 Likes on 5,396 Posts
If the return and vent lines are reversed it will puke till the vent gets air.
Old 04-13-2013, 07:38 PM
mdanehart's Avatar
mdanehart
The engine was rebuilt before I purchased, but I know the builder and that was over 500 miles ago. As stated above the bike runs strong.
Couple of questions..
The oil tank is now empty, is there any kind of trip valve or check valve in the oil pump that could be faulty or reset? I am not a wrench or engineer, so please accept these novice questions. I can do a decent job of a parts replacer.
Can over filling the oil tank create this issue?
I switched from 20 w 50 to 50 weight just before this incident, any issues there?
Thanks
Old 04-13-2013, 07:57 PM
bluharley's Avatar
bluharley
Over filling the oil tank will force oil out the breather. I had a problem where oil was getting sucked out the primary into the crank. The tank would get to the fill line, and from there it would just pour out the breather.
Old 04-13-2013, 08:10 PM
mdanehart's Avatar
mdanehart
Bluharley,
The tank now appears to be empty...refill with two or three quarts and try again..? Just hate to waste the oil, but I may have over filled, and yes my eyes do have 60k on the clock!
Old 04-13-2013, 08:14 PM
bluharley's Avatar
bluharley
Mine would just puke when it went above the fill line. you have a different issue. Did the last guy ride it 500 miles without any problem?
Old 04-13-2013, 08:28 PM
mdanehart's Avatar
mdanehart
No problems..I replaced the CV with a Mikuni, other than that no problems.
Quick Reply: Oil pouring from crankcase breather.help!
