carb leaking
Old 05-06-2013, 04:34 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
The plastic bracket is bonded to a knurled brass fitting so they cracks can just be cosmetic but it will go one day. One fix is to remove the plastic and attach the fuel line directly to the brass but it requires a bit of ingenuity.
Old 05-06-2013, 04:40 PM
RidemyEVO's Avatar
RidemyEVO
RidemyEVO is offline
Thanks Spanners I think I'm going to look into getting a cv , found out today my number 1 son confiscated the spare cv I had for his sporty hes building.
I think I'll look into a Dales Sanders Killer Carb and I guess I'll have to find a bracket for a side enrichner next to petcock. Any idea if the butterfly throttle cables will work on the cv?
Old 05-06-2013, 05:01 PM
RidemyEVO's Avatar
RidemyEVO
Ok carb is ordered and manifold is already on the way, just need the flanges and need to verify whether the stock cables from the butterfly carb will work for the new cv carb?
Old 05-06-2013, 05:15 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
They should.
My stock throttle cables worked fine when I changed to an S&S E so I see no reason they wouldn't work going from a butterfly to CV.
Old 05-06-2013, 05:19 PM
RidemyEVO's Avatar
RidemyEVO
Thanks Tex, one more thing out of the way. Now I have to find the little bracket for the enrichener that mounts next to fuel shutoff. I was just going to order the one Dale has for his Killer Carb that mounts on the top but I really can't see there being enough clearance.
Old 05-06-2013, 05:30 PM
RidemyEVO's Avatar
RidemyEVO
Will the stock aircleaner backing piece work ok bolting to the cv carb?
Old 05-06-2013, 07:32 PM
RidemyEVO's Avatar
RidemyEVO
Ok the nice thing about having 2 evos the same year is easy comparing parts. So it appears the back bracket is differnt but I got one off my buddy so good with that. Now have to find her a a/c chrome cover with the chunk out on top.
Old 05-06-2013, 08:32 PM
RidemyEVO's Avatar
RidemyEVO
Anyone try to peel the logo off the aircleaner chrome cover? I found one for good price but its logo looks like crap.
Old 05-06-2013, 08:39 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,515 Likes on 3,772 Posts
Is this what you need for the inlet?
http://www.johnsmotorcycleparts.com/fuel_elbow.htm
Old 05-06-2013, 09:59 PM
doctorgoo's Avatar
doctorgoo
doctorgoo is offline
The cable for a butterfly has about 2" less exposed cable at the end. If you don't want to buy new cables, you can just trim back some of the housing with a dremel tool. Otherwise you'll need new cables.
Quick Reply: carb leaking
