sifton oil pump installation on evo
Does anyone have a diagram for the sifton oil pump for evo applications? I can't determine where the second line from the top of the oil tank is supposed to tie into the oil pump. any help would be appreciated. If you have one installed maybe a pic.
Pinetop
Pinetop
trial and error answers
Thru much trial and error this is what I have learned. Oil pump gears with dots on them should be mounted in order for the side by side gears to have the dots on the same sides. In an evo application the sifton oil pump should be connected with the supply line from engine to lowest "side" orifice as this will allow the pump to the most oil no matter where the bike is titled. It did not even need a prime after the lowest one was used.
Just finished my first 50 miles of break in on this stroker. Now to 2500 rpms for 500 miles oil change and then up to 3500 for a 1000 mile then it is "ON"
Pine top
Thanks dr. and spanners, and the rest of you guys I am enjoying my days now.
Pine top
