Oil usage in Evo
Oil usage in Evo
I have a 1990 FXR with 60,000 plus miles. I bought the bike used with around 55,000 on the clock. The previous owner told me the engine had been rebuilt around 53,000 miles. The bike seems to use a lot of oil but I do not have any leaks anywhere. It used half a quart on a 700 mile trip and this was going easy on the throttle. What are possible problems and solutions? Thanks.
Received 4,317 Likes
Don't know what weight oil your using, or how hot it is where you've been riding. But I 'm betting it's been over 90f, so if that the case and your running 20/50 wt it should be ok. But, you can try running straight 60 wt . The manual states it's what you should use when riding in temps over 80f. May not cure all the consumption, but should slow it some.,,
If the primary oil level checks OK, then do a compression test.
You could do these checks in reverse, but checking the primary oil level doesn't require anything other than hand tools.
Cold is fine.
Get a 6X6 or even and 8X8, and put it under the bike, use wood shims to get it straight. Three machine screws hold the derby cover on. There will be a large o-ring under the cover. If the level is well above the clutch basket, there's your problem.
Pull the spark plugs and see if they are all cruddy. That's an indication that you might be burning too much oil. Oh, don't over tighten them when you re-install.
