Gas Tank tube - Vent? Overfill?
Old 09-06-2013, 01:12 AM
ecsjr's Avatar
ecsjr
ecsjr is offline
Default Gas Tank tube - Vent? Overfill?
Trying to figure out if I should have a hose on this tube coming out if the bottom of the gas tank on my 1990 Springer Softail.
On the bottom of the gas tank, there is a tube sticking out that has no hose attached to it. Its right behind the tube that balances the fuel between tank halves.
Is this a vent ? or an overflow? Should I have a hose connected to it that runs down and exits below the frame?
Thanks for the help.
Ed '90 FXSTS
Old 09-06-2013, 03:55 AM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Overfill vent, should have a tube on it that runs along the frame backbone and down out the back of the tranny.
Old 09-06-2013, 04:26 AM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 1,742 Likes on 928 Posts
While I don't know for sure, I think that little vent is an option for a California models and not used on your bike (but all tanks are made with the vent tube option).
I had the same short elbow/tube capped off on my 87 sportster from the factory. A vent was only used for California models for a charcoal canister under the seat.
All other states models did not use it so it is capped off. The paint looks factory to me, and the little cap on the tube (braised or soldered on) looks factory to me as well. I say leave it alone.
Most likely your gas cap is vented to the atmosphere. YD
Old 09-06-2013, 05:37 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
Ed '90 FXSTS
Wither it is a vent or an overflow gas has the potential of coming out of it.
Do you really want gas running down the top of your hot motor?
Put a hose on it for piece of mind.
Old 09-06-2013, 07:56 AM
Yankee Dog's Avatar
Yankee Dog
If it is like mine, then it is capped already. I have seen these before. A cap soldered or braised on before the tank was painted from the factory....YD
Old 09-06-2013, 12:22 PM
Jim Kraft's Avatar
Jim Kraft
Jim Kraft is offline
Put a small hose on it and blow through it. If you can get air through it it is open and you should put a hose on it. If you cannot get air through it it is sealed and you don't need to do anything.
Old 09-06-2013, 05:10 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is online now
Received 3,704 Likes on 1,989 Posts
If memory serves, I had one of them on my '89 Sporty. It was soldered shut and painted over (49 state bike). By '94, the vent had been moved to the top of the right side tank on the Softail, behind the right gas cap and under the dash. On my '94, the vent line runs from there to the swingarm and terminates with a hose barb attached to the swingarm. On the California bikes, that line runs to the charcoal canister.
Old 09-06-2013, 11:19 PM
ecsjr's Avatar
ecsjr
ecsjr is offline
Thanks guys, I will look at it from the other side and see if it is sealed.
Old 09-06-2013, 11:25 PM
cowboy 51's Avatar
cowboy 51
cowboy 51 is offline
My 94 has a hose that runs down like spanner said ,it's a vent , put a hose on about 2 ft long & run it down in between the tanks & under the seat down by the tranny
breal2009
Carburetor Related
12-21-2017 05:56 AM
oldhokie
12-14-2010 10:42 AM
HDZellm
Exhaust System Topics
10-29-2009 06:33 PM
ILTim
05-02-2008 01:00 PM
tony2nuts
06-15-2005 12:49 AM
Quick Reply: Gas Tank tube - Vent? Overfill?
