How to fix front brake light switch?
I have seen two different symptoms. The first being that the brake light just does not come on and I have seen a brake light flicker with no pressure to the handle. I would definitely look at the handle as a problem before cutting and soldering on a new switch. Start with cheap and easy first.
Bad switch ?
If it is , try cleaning out the switch first as they do get dirty enough to gum up the contacts and small springs to the point were they will not operate.
I took the handlebar switch housing apart and in there it looks like there are 3 switches guessing ignition cutoff/starter, right turn signal & brake light. The are in there good with what looks like factory solder and a plate with a screw. Really tight in there. I checked the contact point and it appears that the circuit activates when you pull the lever bringing it out of contact with the switch at that ooint. The contact point is just this tiny black dome thing on the outside of tge housing where the brake lever woukd sit while disengaged.
Is there anyone that can help with a way to test the switch before try to track down a replacement and I swap it out?
Was hoping the contact point was just out of alignment with the brake lever but after looking at it, I think if that were hapoening it would be stuck on not off... is my logic correct?
Any other fix help is appreciated.
Thanks
