The (re)(re)(re)rebuild begins again
she's prepped and ready.
began the swingarm upgrade tonight too. she's basically stripped to the bare frame from the trees back at this point.
hoping graham will chime in on this one, because im not 100% sure with what I want to do yet regarding the pivot shaft (whether to stick with 5/8", and buy $250 adapter bushings), or have the transmission bored for the 3/4" shaft (which I already have) and just buy the *much* cheaper urethane bushings.
as a note, apparently I push this bike pretty hard. I have a bagger brace (forget the brand), and I managed to actually SHEAR the bolt where the heim joint bolts to the dogbone. didnt happen in the accident....that bolt was on the right side, i went down on the left.
planning on a tranny inspection (measure / re-shim / adjust as necessary), simply because it's out anyways. ive got all winter to kill...this bike likely wont see pavement til March.
and so it begins (again)
Received 4,317 Likes
HF lift? Buy extensions for it? GOOD LUCK!! Oh and i was advised by several guys not to bore bigger.....but i aint there yet.
Don't try to bore the trans, that is a precision job best left alone! From what I can make out the brands that sell alternative bushings also sell the conversion variety you need, certainly HDF sponsor Motorcycle Metal do. Those bushings improve handling as well, by dumping the cleve blocks, so they are both a replacement and enhancement! A stock one piece 5/8" axle is all you need, but replacements come in those bushing kits because they commonly corrode and suffer damage in being removed.
Received 4,614 Likes
I'm pulling the swing arm on my 89 Tour Glide this winter, too. Haven't decided which yet, but will upgrade the pivot hardware, not oem Harley. Won't quite look like yours, will be on a jack I can roll, in the living room, won't pull the engine (I hope), but will have the front end off for a fork rebuild. 120,000+, all new bearings outside the cases, too, it deserves it. A weld repair on the tour pack rack. Brake pads, tires, wheel bearings, all the tins coming off, some weight reduction, wiring cleanup; this is probably going to end up bigger than I planned, but that always seems to happen.
I never leave a helmet in the garage, either; not just bugs - had a squirrel ruin a Simpson I liked better than any helmet I've had since. They seem to like digging the insulation out. For some reason a bunch of squirrels died in my yard after that... and still do.
I bring mine in and take the pads out for cleaning when the season is over for a while.
Dying squirrels? You sure you aren't doing some "plinking?"
Good luck with the rebuild, that S&S will be interesting and more than likely ruin some underwear
