Removing 1990 evo motor.
Old 11-17-2013, 02:59 PM
machinehed's Avatar
machinehed
machinehed is offline
Default Removing 1990 evo motor.
In the middle of pulling the motor out of a 1990 FLT . Manual says to remove the 4 primary housing - to - engine mounting bolts but dosent mention if the stator needs to be removed to access them ? Manual says to remove the compensator only ? Am i missing something here ?
Also ... do i need to remove the left footboard and bracket to remove the primary cover ?
Thanks to all .
Old 11-17-2013, 03:25 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Depending on the make of footboard you may need to remove it....stator doesn't need to be removed to get at the primary bolts or to remove the primary BUT!!! I would take it off while the motor is still in the frame as they can be a pig to remove against all that magnetism and its gotta come off to pull the motor apart.
richard567
EVO
04-23-2017 06:27 AM
cajun1957a
Shovelhead
108
02-23-2014 01:01 PM
machinehed
EVO
14
12-04-2013 05:20 PM
mark7164
11-29-2012 06:00 AM
paullavery
Classic
09-15-2009 02:52 PM
Quick Reply: Removing 1990 evo motor.
