AVC question
AVC question
Anyone know where the radio pics up the auto volume control signal from? There is nothing in the speedo. Nothing else makes sense. I looked at the schematic, and I don't see anything relating to the AVC. My AVC used to work even though the speedo wasn't, then it just stopped all together.
Ah yes, thanks Shex. It looked like a fuse, sorta, but not really, just didn't put 2 and 2 together. My problem is the part the cable screws onto popped out of the speedo. I'm waiting on a FLH panel to arrive, hopefully that speedo is the same. It's off a police special, so ....???? Should be the same though.
It's there, it looks a little cooked, but it's there. I'm sure it will work fine with a different speedo, even if the speedo don't work. I understand it now. Why it worked when the speedo did not, that was puzzling me. But as long as the cable is spinniing that wheel, and it is aligned properly, it will work.
