Oil baked on muffler, how to get off
03-04-2014, 04:22 PM
When I was puking oil out the breathe like a hose, the oil baked onto the bottom of my right muffler. Regular cleaning stuff doesn't touch it, and I sure don't want to take a razor blade to it. Any suggestions?
03-04-2014, 04:44 PM
#0000 steel wool should do it. I've used with with no problems. I have used it with a splash of wd-40 on the wool for lube.
03-04-2014, 04:48 PM
NOOOO. Easy off oven cleaner.. But that stuff is very toxic, keep it off your skin and don't breath it...
03-04-2014, 04:57 PM
Quote:
Originally Posted by
FlyingSpur
Thanks! I didn't have steel wool, but I had some scotch bright. That WD-40 did the trick, came right off.
03-04-2014, 05:10 PM
bluharley
Umm, scotch bright was a bad idea... The light is bad right not, and I just wanted the tar off, but scotch bright was a bad idea. Anyone got a set of stock mufflers lying around???
03-04-2014, 05:21 PM
No but Easy off oven cleaner works good.
03-04-2014, 05:34 PM
You need to give that baked on crap a good ole fashioned........
03-04-2014, 05:41 PM
Well, the oil is gone, now I need to get rid of the scratches
03-04-2014, 05:46 PM
03-04-2014, 05:47 PM
Dr.Hess
Flitz.
Where do I get it?
