stock heritage springer exhaust any good?
Hi Guys, I have the chance to buy a stock set of heritage springer exhaust for my 99 stock heritage softail, my Bike is all stock with the se air cleaner and jet kit, and se mufflers, just wondering if I will loose power with that stock springer exhaust? I really like the way the stock springer exhaust looks, wondering if or how much power I would loose? Thanks
Stock. yes
Sno,
After installing the stock exhaust, you may lose a bit of power. She may run a bit rich as well. That said, I think that the 97-99 Heritage Springers were the best looking Softails HD ever produced. Even if you don't install the stock mufflers, I'd buy them anyway. It will help maintain bike value. In my opinion keeping her stock maintains value.
Oh yes, welcome to the forum.
Sno,
The 1999 HD parts catalog displays hp and torque curves for their Screamin Eagle performance upgrades. Most HD dealers still have parts catalogs that go back to 99'. I'd check them out. It will provide general performance expectations of stock vs 1,2 and 3 stage Screamin Eagle upgrades.
That said, the only way to know for sure is to have it dyno'd with each set of muffles. Your the only one who knows if that's worth the effort.
On my bike I went from stock with the baffles removed, to completely stock, to a set of Screamin Eagles. The only think I noticed - besides a difference in sound, was a difference in MPG.
The stock FLSTS crossovers are nice, but the mufflers are catalytic converters, which IMO will rob you of power. But you could always just use the FLSTS Header Pipe crossovers, and use your SE Mufflers to complete the system. In doing so I don't think there would be any noteable difference in performance.
Received 3,222 Likes
Accessory catalog for '99 states the SE set up gives you about 15% increase in torque (at the peak) throughout RPM range. States the SE is designed to work with stock mufflers. Guess you have to assume you will give some of it back.
Regarding using your SE mufflers...catalog lists 3 different ones for your Softail, 2 slash cut (shorty duals and shotgun) and 1 straight cut (shotgun exhaust). Thinking it is probably the mounting system that differentiates them?
Back then the price on the dual exhaust system was $599 before tax and you still had to purchase the tips which went from $32-60 depending on the tip (there were 8 offered). What type of tip is on the set up you are looking at?
