Wood's 41.5 CV Carb
I have forward control pegs mounted & the stock pegs. No problem with the stock pegs, but when I stretch out on the forward pegs , the air cover does get in the way. But I have a plan. The air filter on the right is the one that came with the kit & is 3.250 tall. On on the left I got off flebay & is 2.750 tall. That will give me .500 more clearance. Have holes in shorter filter & had to make a set of shorter stand off's to bolt the filter to the backing plate. I'll have both filter's & hardware at my indy's when we put it on the dyno & tune, hopefully this week. Rode about 60 miles today & did ok, but seems a little sluggish & some popping when I decel, which didn't happen before, but it isn't tuned . Close but not right , yet. Will post up dyno #'s when done.
Ride Safe,
Harold
Ride Safe,
Harold
Lol
LOL! No, had em at work to drill the mounting holes & looked like a good place to take a pic. Scale measures close enough. But we do have a couple of CMM's if I need to get REAL close! LOL
Ride Safe,
Harold
Ride Safe,
Harold
that's good I almost thought I had a twin out there my Starrett table and height gage cost more than most ppl bikes and I used it to measure how tall my risers were :P
Dyno Update
Got bike on dyno, Fri & got her dialed in. Carb was lean on all jets & needle , out of the box. Humidity was up, bout 15% higher than the last run, so #'s were down a point or 2. Close enough to see the CV keeps up with the S&S on that part. What I'm interested in is gas mileage & the characteristic's of this carb. Weather has been crappey this week, so I'll post back in a few weeks on gas usage & initial feel for the carb. Real test will be in a few month's , when the temps will be well over 90, here in the deep south. Set everything up with the shorter air filter on the bike, so I got my legroom back, but we did one run with the longer filter with basically NO difference. So unless you have a big inch motor, don't waste your money & your legroom.
Ride Safe,
Harold
Ride Safe,
Harold
Ride Safe,
Harold
Ride Safe,
Harold
http://www.woodcarbs.com/air.htm
Ride Safe,
Harold
blair
10-09-2011 07:11 PM
