oil light on after cam install
Old 04-10-2014, 01:10 AM
apples402's Avatar
apples402
apples402 is offline
agree 100%, hindsight is 20 20 may be needing advice along the way on teardown and cleanup. if i can.
Old 04-10-2014, 04:47 AM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Mate, we are here to help you.....
Old 04-10-2014, 07:46 PM
apples402's Avatar
apples402
was busy today with work responsibilities...drained oil pulled filter, and cut had a few filings in there and the lines small stuff filled oil tank with kerosene gonna let it set going to replace all oil lines also as they still have the factory clamps on them. ordered overhaul gasket set, and getting new rings when i see if it is still stock, they claim they will have them in stock. 30 mile one way trip to dealer. am i forgetting anything? will probably be sunday before i can work on it again. bummed but resigned and satisfied of the fact that i will have a fresh engine on a bike with 45000 miles. this bike is really clean and i wouldnt trade it for anything ive seen as yet. thanks in advance
Old 04-10-2014, 07:57 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
after taking the top end off in place ( and re install after you put the block back in the chassis ) that is the way we do it in my shop found it to be easyer if your alone --
when you get to spliting the cases the right side will slide off the left side but a press will be needed to remove the left case from the flywheels - special tool needed to re install the flywheels into the left case <
pushing on the tapers using a press to re install the flywheels can and will put them out of true, rent or buy the tool or it will become the same mistake -- johnjzjz
Old 04-10-2014, 08:39 PM
apples402's Avatar
apples402
i am just wondering if i really need to remove the flywheels from the left side, is this to check bearings? if i am just cleaning cant i just remove right side clean and reinstall with new seal? I am on a limited budget and i have heard that bottom ends rarely fail, am i way off?
Old 04-10-2014, 08:46 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
you are good to go if you are sure a piece is not imbedded in the alloy behind the flywheels
not trying to jinks the job but i cant take a short cut if it do the quick sand gets me
Old 04-10-2014, 09:10 PM
apples402's Avatar
apples402
thanks good to know there is a shovel mech in town who can do this part for me if need be.
Old 04-10-2014, 09:13 PM
D_gyver's Avatar
D_gyver
D_gyver is offline
don't forget your threebond 1194 or yamabond or hondabond or harleybond all the same stuff
Old 04-10-2014, 09:22 PM
apples402's Avatar
apples402
that is to seal the cases back together, right? it isnt in overhaul kit?
Old 04-10-2014, 09:47 PM
D_gyver's Avatar
D_gyver
D_gyver is offline
I have never seen it in a kit but I could be wrong if you have a Honda or Yamaha dealer close by pick up a tube its cheaper than harleybond if you have never used it before
here is a few things to remember
#1 prep prep prep make sure both halfs are clean and dry brake cleaner work good to get the old glue off
#2 a little goes a long way about 1/16 bead all the way around and around every hole
#3 wait 24 hours full cure after gluing them together before you put any oil near it
Quick Reply: oil light on after cam install
