oil light on after cam install
put a new cam in today. new lifters new cam bearing, 92 dyna glide. the old cam had a worn lobe on it causing it to be noisy. everything went fine started and ran fine, rode around town for about an hour suddenly the oil light comes on, it is not ratteling took the oil sending unit out and it is burbling oil out dont have a guage but it seems to have some oil pressure. what did i do wrong?
You can pull it out of the pump and clean it up.....I have never run a motor with the sender removed so can't answer your question.
If you pull the tappet screen and turn the motor over on the starter (plugs removed) it should make like the last scene in a **** movie.....
If it doesn't then the relief valve is probably stuck....but there could be other causes but as with anything....try the things that don't require money to be spent first of all.
well things got bad, scavenger gear in oil pump broken. did additional inspection and found needle bearings in behind breather gear. got those out looked at old cam bearing and i must have lost some rollers when pulling. this is frustrating..$400.00 for new pump and have to wait until monday. im assuming the bearings got in the passage behind cam bearing and moved in behind breather, i found 2 there and i am assuming one fell into cam chest and made its way to pump. is there any other place i need to look might be still missing one more if it fell backwards into passage behind cam could it be in crankcase? if so could it make its way back to cam chest.
question were they broken pieces of the full length rollers
the roller you took from the oil intake hole to the pump was it broken ( that broke the pump gear ) was it a smaller piece
reason the plastic breather gear has large slots and if this is small pieces than OH Boy
if this has happened as you posted i am sorry to inform you but this will happen again if you dont split the cases and remove all the roller pieces from the crankcase
i have never seen that and i had thought i had seen it all so to speak i stand corrected if this is the case -- johnjzjz
they were all full rollers. i think they slid down the bearing boss into the breather gear area, not blown up there, is this possible, i am looking at the oiling diagram in the manual and it doesnt look like the passage behind the cam goes down into the crankcase, am i wrong. also the return passage from the crankcase is up about 2inches how much oil stays in crankcase or is this all mist?
