Front brakes and Fluid
[QUOTE=Spanners39;12583563]If they are off centre then you have problems....only seen it with aftermarket rotor spacers on wide glide conversions and when the bolts are not tight.
You will always be able to hear the pads rubbing on the discs when you push it around though.[/
QUOTE]
+1 new pads do it too.
QUOTE]
Received 4,317 Likes
I checked that sorry for the misunderstanding. I checked the spacers. Had to put a new axle on yesterday and while it was apart I checked the clearance side to side
Measure with a micrometer or a pair of dial calipers.
Honestly, if the bike rides fine, and stops fine then I'd leave good enough alone. As stated, you will always hear the rotors brushing up against the pads when you rotate the wheel. Don't pole vault over a mouse turd.
