Open belt drive help
Ok, so the bike will be down for about a month, so I figure now is the time IF I'm doing to do it, put a open belt drive on it...been reading this morning and there is so much chit about do's and don't... anyone in here actually run one? What happenes if you're out somewhere and that belt breaks? I don't even know how the sum-beech goes on there yet...But was just wondering what you guys thought? Are they noisy? Some said they are, some said they wasn't. . Why are they saying don't go under a 3 inch's belt? Cheap ones good as the BDL unit? I AM FULLY AWARE TO KEEP YOUR PANTS AND FOOT AWAY FROM IT WHEN THE MOTOR IS RUNNING OR RIDING!!
Received 5,008 Likes
OK here you go. I put a 2" open belt on my 1997 Wide Glide three winters ago, this is what I went with:
http://www.ultimaproducts.com/beltdrives2.html
The open drive is narrower than the stock primary and therefore actually increased my cornering clearance. I had plenty of rub marks on the bottom of my outer primary cover when I removed it. So far zero complaints or issues, I love it. Yes it makes noise, especially when you are stopped with the clutch disengaged and in gear. But I love the noise as well. Reminds me of a Ducati with all of the rattles. I have 2" extension on my forward control so my pants are not near the belt so I am running it with no guard. This is the best picture I have of it on hand:
Part of the job for me was to also change the rear belt to a 1-1/8", via a conversion kit that HD sold in the early 2000's. My local dealer did a search and found it for me. It is just a new belt and a rear pulley that is narrower but has the bolt pattern to fit pre-99 wheels and it is spaced appropriately. With that kit I was able to put a 150 on the back of the bike as well. Overall a great pair of upgrades.
I have run a 3" BDL with no bearing support for 11 years without any major issue. I've beat on it pretty hard wth a 113" . I have replaced the clutch plates a couple of times and I have put holes in the belt by sucking in a rock on a gravel road. I've never had a belt fail yet. My current belt has had a small hole in it for a couple of years now. I probably wont change it unless it gets worse. The dry clutch is noisy but I like the sound. If I wanted a quiet bike I would buy a BMW.
