What to do if your clutch cable is too long???
Old 04-15-2014, 11:24 PM
Pinetop's Avatar
Pinetop
Pinetop is offline
Default the manual way is the only real fix.
Originally Posted by AAAC
I did this exact procedure and after I did, I wasn't able to get the cable to tighten back up. I had about 5/8" play between the ferrule and the clutch lever assembly. I then tried to put some spacers in to see if the clutch would work and the lever would not pull in. This is when that old timer stepped in and readjusted my clutch pack...which got things working OK but I don't know if it's adjusted right.
can't tell you what to do but I bought my bike with apes and changed them right away. Clutch never worked correctly until I bought new cable, stock length and then followed the manual adjustmest procedure. Very litle issues with clutch since then.
Old 04-15-2014, 11:56 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
If it works its probably right.....the clutch centre adjustment isn't difficult, there just needs to be a tiny amount of free play between that adjuster and the pushrod.
Old 04-16-2014, 12:03 AM
AAAC's Avatar
AAAC
AAAC is offline
I think I'm going to take my chances with "leaving good enough alone" and hope he didn't tighten it down too tight. I just got off the phone with the old timer and he said that part of the problem was that I had the center adjustment too loose. He said the other part of the problem is my cable is too long and I probably need a cable about 1" shorter than the one on there...which is probably not available unless it's a custom made cable. So, I'm going to hope she's adjusted right and ride her! Thanks!
Richard Winquest
EVO
06-15-2017 06:45 PM
machm1969
05-07-2013 05:00 PM
Indy Road Dog
04-23-2011 09:08 PM
Mike O
02-02-2011 06:19 PM
skos
10-23-2008 03:46 PM
Quick Reply: What to do if your clutch cable is too long???
