White spark plugs
White spark plugs
Im still tinkering with my new adj ignition and jetting.
I installed new NGK Iridium bpr5eix-11 so I could get a better look to see how lean I was running. After 50 miles they look too white. Im still running "pure gas 90 octane". The 74 main jet blacked the old plug and changed to 72 main & now their white.?
Tomorrow I will retard a 1/16 inch to see where my heat band goes on the strap.
Thanks Spanner, I will defiantly keep that in mind. I called NGK Tech and he recommended That I do have the correct plug [ BPR5EIX-11 ] and for me to richen the carb screw for now.
If need to, I will go the next cooler plug [BPR6EIX-11 ]. Tech said IF I go cooler there would be a chance of carbon build up.
So, what harm is it to have "white" plugs?
