Is the Voes a wear item?
Received 4,317 Likes
So basically there is no time that they should be replaced.
Correct?
I'm very close to that now.
When the switch failed on the Sporty, the bike was all but undriveable, as the switch kept going back and forth between the two advance curves at random times, every few seconds. It acted like a real bad manifold leak.
The Softail apparently got stuck on the "advance" curve. The bike ran well, but began pinging under acceleration. After ruling out fuel and the usual suspects, I checked the VOES and found TWO failures. first was a vacuum leak from an punctured diaphragm, and second, the contacts were stuck in the shut (advance) position. This surprised me, because the normal failure mode for a bad diaphragm SHOULD have been to leave the contacts OPEN, and the ignition on the "retard" curve. Vacuum is required to close the switch, activating the "advanced" spark curve. No vacuum-no advance. But my ohmmeter and the way the bike ran didn't lie.
Curiosity mainly.
Tina has 19 years and 140k miles and I am just going through her.
Since the VOES has a rubber diaphragm I didn't know how long it would last.
