Need help wiring a new tail light
1995 Electra Glide. I bought a Drag Specialties lay down blue dot tail light. The light has a red and black wire. The light I removed has a black wire, blue, and red/yellow. My manual shows the red/yellow to be the stop and I believe the blue to be the tail. The black has no label best I can tell with my best reading glasses, man the print is small. I am not 100% the blue is the tail with the small print. Can someone point me in the correct direction? thanks
I may have found my answer on the web. The pictures shows mounting the original black wire from the harness to the tail light mounting bolt for a ground. The red/yellow wire from the harness connects to the black wire from the tail light for the brake light. The blue wire from the harness connects to the red wire from the tail light for the running light. Does this sound correct?
simple use a 9 volt battery and swap the wires around till you get the tail and the stop lights to work and write it down tail color stop color and what wire is the ground if its all plastic - then turn the lights on see what color is the tail then the stop light and your good to go with connecting the right colors to the bikes colors
the OEM tail light is USA made and it has a metal back plate so it does not need the 3rd black wire that is the ground for the new light -- in your case the 3rd black ground should be fine under the steel mounting bolts for you new light to the fender -- try it the light should only work if you ground it -- you can also bolt on the tail light then use another nut on one of the mounting bolts to put that back wire on and the light will be grounded - no need to string it all the way to the battery
