dresser fork removal questions
Old 07-21-2014, 08:39 AM
Schex's Avatar
Schex
Schex is online now
Received 6,816 Likes on 1,760 Posts
If your not replacing the springs or need to replace # 30 in above parts picture, no need to remove end cap, the correct allen drive socket, impact wrench, snap ring pliers, and a split pvc coupling and a hose clamp are the only tools required to replace seals.
Lovely thing about the anti-dive air system is the easy, 20 minute fork oil changes, which also makes it possible to replace seals and bushings without getting into the fairing.
Remove schrader valve, drain oil, use a mighty vac connected to the air valve to pull new oil into forks, I use 11oz of 10 or 15w BelRay in each on mine.
Old 07-21-2014, 10:37 AM
HGM's Avatar
HGM
HGM is offline
Originally Posted by Schex3x
You can disassemble the lowers and replace the fork seals and bushings without removing the fork tubes or the fairing.
How do you do that with the cow bells covering the snap ring?
Old 07-21-2014, 11:27 AM
Schex's Avatar
Schex
Schex is online now
When the #13 allen head bolt is removed from the bottom, the lower will drop down.
Old 07-21-2014, 02:02 PM
HGM's Avatar
HGM
HGM is offline
Hmm, didnt think it would go far enough.. Good to know!
Old 07-22-2014, 06:35 PM
beedubb's Avatar
beedubb
beedubb is offline
1st Gear
All good news, thanks all- I had something occur to me and looked at the previous owners bills- the seals were done about 20000 km ago. with this in mind, i looked at the oil leak- and the hose connecting the air solenoid to the handlebars was loose and leaking oil. replaced it , put in 10 psi, and it is still holding today. the oil was leaking out there and running down, it looks like the seals are fine!!!! great!, and also good to know that seals can be done without removing forks. now back to painting and new tires and front brake lines to try to get rid of the mushy feeling which bleeding doesn't help.
Old 07-22-2014, 07:19 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
Use braided brake lines.
jayhawkclint
2014-2023 Touring Models
08-25-2014 12:34 AM
Michaelkristensen
01-15-2013 03:39 AM
mglax13
01-18-2012 10:19 PM
98springer
01-02-2012 06:19 PM
trigger1911
01-17-2010 01:44 PM
Quick Reply: dresser fork removal questions
