RPM Danger zone?
Old 07-23-2014, 07:35 PM
traildog's Avatar
traildog
traildog is offline
Default RPM Danger zone?
What should my RPM limit be set to on my ignition? I have it at 5500 currently.
Old 07-23-2014, 07:41 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,689 Likes on 1,341 Posts
Whatever makes you feel good. I don't have a rev limiter on mine at all (SE ignition without a rev limiter.) I run it until the valves float and consider that my rev limiter.
Old 07-23-2014, 07:45 PM
deano360's Avatar
deano360
deano360 is offline
i normally dont run against the top end that much and if i do its not for every long... so i dont worry about it, if i need the get-up-and-go, i drop down a gear
Old 07-23-2014, 07:55 PM
aces&8s's Avatar
aces&8s
aces&8s is offline
Set it at the lowest 5500 rpm. We don't run these at NHRA, and they will last longer. If your carb ever stuck open you will be glad you did. Even when I let the dogs out I only push about 5300 and still smoke the competition.
Old 07-23-2014, 07:59 PM
traildog's Avatar
traildog
traildog is offline
What happens when the valves float?
Old 07-23-2014, 08:07 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,524 Likes on 2,865 Posts
they become fishing bobbins
Old 07-23-2014, 08:10 PM
aces&8s's Avatar
aces&8s
aces&8s is offline
Or possibly cute paper weights.
Old 07-23-2014, 08:11 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Motor won't run any faster.
Man ya'll are easy on your motors. I lost a speedo once on the way to Sturgis. I just set the tach at 4100-4300 in 5th gear and left it there, basically for 1K miles. On the way back, I kinda realized why I was passing everyone.
Old 07-23-2014, 08:12 PM
traildog's Avatar
traildog
traildog is offline
Why you buncha smart ..................I'm guessing that floating the valves is a bad Thing.
Old 07-23-2014, 08:16 PM
aces&8s's Avatar
aces&8s
aces&8s is offline
Trail you don't have to EVER worry about floating a valve the way you drive.
Quick Reply: RPM Danger zone?
