gasket between ac and carb
07-24-2014, 07:57 PM
Is it a necessity? Mine crumbled..........prolly the seafoam, not!
07-24-2014, 08:05 PM
that only happens when the motor is about to explode
dont worry you dont use slippery oil so you dont have to be concerned
07-24-2014, 08:08 PM
Quote:
Originally Posted by
johnjzjz
Huh???
07-24-2014, 08:19 PM
Yes it's important... that's like asking if a head gasket is important.
07-24-2014, 08:30 PM
traildog
Mine has run fine without it for years now.
07-24-2014, 09:07 PM
tmanbuckhunter
Head gasket?
texashillcountry
Not needed at all?
2 vastly different opinions for sure. The mechanic at the dealer said if it makes me feel better, use it.........
07-24-2014, 09:10 PM
Why run an aircleaner if you're going to have an area where it can suck in unclean air?
07-24-2014, 09:46 PM
[QUOTE=tmanbuckhunter;13026811]Why run an aircleaner if you're going to have an area where it can suck in unclean air?[/QUOTE
Good point.
07-24-2014, 10:03 PM
it depends on what air cleaner you run. if you run a k&n or that type you don't need it. the k&n filter will let more dirt in your engine than that missing gasket. so there's no point
if you run a good air filter I say yes you need it because you care about your engine.
07-24-2014, 10:06 PM
D_gyver
If K&N is not good what is a good one?
