What do you guys do about tires?
I let my indi handle them.. A few reasons actually.. #1 They are very good at what they do.. #2 they are always available and willing to talk to me, I consider them to have become friends.. #3 Since I do 99.9% of my own work, I think the least I could do is to spend a little money there, even if its tires.. They are set up for it, have the tools and experience.. The extra money is just worth it to me.. I don't have to worry about hurting a bead, truing my spokes or pinching a tube...... I take em off and bring them to him to do whenever he can work it in, always same day or next.. Bike tires are just such a critical component, I feel better about it, not that I couldn't handle it, I trust them to do it right.. If you don't trust the guy doing your tires, by all means, do them yourself ,its your life..
As for balance. I think it all really depends on how you ride.. I had them do a last minute rear tire change for me when I first got the bagger. I decided not to have him balance it since we were after hrs.. Anyhow, at "normal" speeds, it felt like a good decision. But, being in Atlanta, I typically cruise at 80+ and felt it there.. So, lesson learned, off it came to balance.. Anyhow, yes they need to be balanced.. I have not tried the dyna beads, personally, but they are a great idea..
I like my Metzler 880's on mine right now. But about a year after there was a scandal on bad manufacturing from one of their plants. Both sets I've had have been good though. The Elite 3's are "supposed" to be comparable. I always take the wheels to the shop. I buy the tire from them and they change it for free. As for balancing, the only time I've had weights on my wheels was from the previous owner and some old Dunlops. I hadn't needed any since.
The day I paid $780 for 2 new tires to be put on plus have my wheel bearings serviced was the day I learned how to do all my own tires.
While I have the tire off the wheel I clean it real good and service the wheel bearings. Much easier to clean a wheel on a work bench than under the bike. Dyna beads make balancing a no brainer. They can be reused too.
Carl
Carl
I never balance a rear tire anymore. all it takes is one good hole shot or lockup to throw it out of balance. the beads in the rear tire is the way to go. as far as the front it definitely needs balanced.
as far as tires I switched from Dunlop to avon a few years ago. and so far im impressed they handle great in wet weather. and last a little bit longer with my very aggressive riding style. I ride all my bikes like I stole them.
and here's something not a lot of ppl know tires have a balance mark on the sidewall its the lightest part of the tire and it lines up with the valve stem. if you use it you wont need as many weights to balance the wheel. also there's a dot on the tread for what is called the match point. ie radial run out Harley doesn't use this mark. but my ducati did.
Received 4,317 Likes
