New to the board
New to the board
Well just wanted to say hello and intro myself. I just bought a 96 Road King FI with 42k on it. The bike was actually purchased 3 years ago by my father with 36k on it and then sold to my uncle last spring. In June my father passed away so I finally talked my uncle into selling the bike back to me. From what I have been able to find this bike has the Evo motor and not the 88 that he thought was in it. Part of him selling it was because he thought it was getting close to that mark where the 88s go out and cost a small fortune to repair.
Are there any things I should watch for on this motor? what options do I have to upgrade the power a little without killing it?
Received 4,317 Likes
Welcome from Minnesota.
If the EFI is working fine, don't screw with it. Signs of trouble will be flooding out, bad / rough idle, and surging. The fixes aren't cheap. This might be the time to go to a carb change out.
You didn't mention how many miles but, cam bearing and lifters may need attention.
It has just over 42k on it.... and funny you mention the surging, when I get to a light the engine light kicks on and the idle sometimes fluctuates. How much would I be looking at to go to carb or what is needed to fix the FI if that is? is there anyway to tell if this is the actual issue? can you pull codes from the engine light?
I'm not sure if the book tells you to but a couple of members here have had trouble (cam bearing going out) at just over 40k.
I liked the EFI idea so I had mine fixed. It was the temp sensor. It was just about $400.
Others are big fans of the carb and can give you a better idea on the cost of the swap.
