Hesitates an backfires on bumps
Old 07-31-2014, 05:38 AM
spanky02's Avatar
spanky02
spanky02 is offline
Default Hesitates an backfires on bumps
So my bike is running pretty good except when I hit good size bumps when doing 45mph and up. Doesn't seem to do it at lower speeds.its just annoying when it's one bump but if I am going through a rough section it gets pretty bad.. I have recently replaced my coil cause my bike was shutting down to one cylinder.. Haven't had an issue with that since I replaced it.. Any help on this issue would greatly be appreciated. My bike is a 96 fxd ev27 cam and arlen ness big sucker intake. Thank you
Old 07-31-2014, 05:53 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,522 Likes on 2,865 Posts
under the center of the bike it has a netted cable ground wire - it connects to the inner primary center bolt from the back side and it attaches to the frames cross brace - the weight of it after many miles has a way of making it loosen the bolts - remove it completly Clean both locations and re install - that is your isssue
Old 07-31-2014, 06:59 AM
spanky02's Avatar
spanky02
spanky02 is offline
Thanks for the quick reply.. I will remove and clean that when I get home from work
Old 07-31-2014, 10:02 AM
spanky02's Avatar
spanky02
spanky02 is offline
do u happen to have a picture of exactly where this wire is?
Old 07-31-2014, 10:20 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is online now
Received 2,682 Likes on 1,339 Posts
Also, with the bike running, (carefully, wearing gloves if you have to) grab the wire coming out of the cone and going down and tug on it. If the motor dies, that wire is broken inside the insulation.
Old 08-01-2014, 05:40 PM
machinehed's Avatar
machinehed
machinehed is offline
Default wiring.
Ditto Dr.Hess but also advise you do this " wiggle " test to all the wiring on this 19 year old . If your up to that you can also inspect / clean / lube any and all switches , breakers , connector blocks etc. to ensure your electrical system is good to go.
Older bikes are great but the old wiring is usually what will make a bad day.
Take care the electrical and you will have one less BIG thing to worry about.
tkuligowski
General Topics/Tech Tips
02-23-2017 01:57 PM
captainmorgan71
04-29-2016 07:44 AM
loose_Change
02-08-2014 07:24 AM
72 Ironhead XLH
08-31-2008 10:59 AM
02Sporty1200C
03-25-2006 10:15 AM
Quick Reply: Hesitates an backfires on bumps
