1990 fxr oil out of crankcase breather and oil in tank smells like gas.
So oil comes out of the crankcase breather. I haven't had a chance to ride it much since I got it. I know that they tend to do that of they sit a while and oil gets in the case so I'm hoping that will clear itself up when the weather finally breaks around here. Second, I pulled the dipstick out to see how much oil was in it and it smells like gas. I'm going to change it tomorrow to a cheap oil to flush it out then change it again with a new filter after 100 miles or so just to flush it all out. Anyone have any ideas of what either could be?
Received 4,317 Likes
Unless you needle and seat are bad in the carb, the petcock being on or leaking would not get gas in the oil...if the needle and seat were bad, gas would leak out on the ground though the overflow tube...so unless you have a bad petcock AND a bad needle and seat AND a clogged overflow tube, that is probably not the case. Since you haven't ridden it much, it could "smell" like gas just from the cranking it with the choke and not actually riding it.
While the oil tank is drained I looked at the ball in the check valve. The ball looks fine, so I made sure all of the tubes from the oil tank weren't blocked, which they weren't. The oil return spit out oil when I turned it over and I blew through the fitting for the oil feed and it was fine. Only other thing I can think of is pulling the cam cover off and looking at the gear to see if it looks okay. Anyone else have any suggestions?
Also I made sure the filter on the bike was an evo filter and it is.
Me and TJ (throttle jockey) were discussing this not too long ago in person and in my thread. It would make sense that if you were using a restrictive filter, on a bottom breather bike it would make it wet sump like that, and on a head breather, it would find somewhere else to spit it out. Is the filter an HD filter? If it is get rid of that **** and put on a WIX 51215 or some other 15-30 micron filter that fits, and has a relief valve opening pressure of 8-11psi.
Run something cheap for that 50 miles, like Rotella, Delo, or some house brand 40-50w oil. No need to put expensive stuff in it if you're going to lose it after 50 miles.
Update years later?
This is literally happening to me right now. Bought the bike from the original owner of an 84. Sat since 07 oil full of gas, starts right up, but had oil spill from case breather. Thought it was running super rich since I’ve been starting and letting it run, gas keeps showing up after dumping oil a few times. Carb stock jets, re-built.. float goes dry overnight (not on floor) like it draining into the motor
