97 FLHT PCIII Custom Map File
Hey guys,
I know how difficult it is for many of the MM EFI Evo guys to find map files for their setups with the pc3, as specially with a stock ECM flash (Not Stage 1). I recently had a "custom" map made by dynojet and thought it may be useful for some people. My setup as of now is:
True dual headers
Rush 4000 Series Slip-ons
Stage 2 Big Sucker
EVL3000 Vthunder Cam
Stock ECM
Stock Injectors
Stock Compression
Shoot me a PM with your email if you're interested in a copy of the tune. I take no responsibility in damage to your bike if something were to happen after this file is downloaded on your PC3. Thanks!
True dual headers
Stage 2 Big Sucker
Stock ECM
Stock Injectors
Stock Compression
That was going to be my next step. Although, I am not certain it is necessary. If I went big bore I would 100% but as of now, I have no flat spots in the power curve and the plugs look perfect. I don't get any goofy pinging or detonation so I am not in any hurry. I do everything in baby steps. I am on a tight budget! haha
I am in a similar situation and would like a copy. Had the jugs bored one size over with chrome molly pistons and the ev-27 cam. Bike ran real hot so I put the PC-III on to get more fuel. cant seem to get it just right been way up and back down till it runs hot again. The problem that I am having is the motor will load up bad after I have ridden a steady RPM. Rev the **** out of it and it will run good till it happens again.
