It's big inch EVO time
John at Mia Cycles has built one stock height, to his own secret recipe! Personally I would only buy a custom-built Ultima, not a crate one. We have at least two Johns who can probably do that!
in my shop we no longer build anything bigger than the 96 inch EVO - 86 inch shovel pan knuckel and sporty 74 inch - 45 inch flatheads to 56 inches and thats it no exceptions - some one else can build what will only be fun for a while like a lot of the girls who date jihadist
been there done that
TP engineering will build ya a 121 in 3 to 4 weeks under 7k, only size they are building now. Nice having them local too. Im running a plus 1 clutch kit, stock starter (compression releases do job fine), thinking on exhaust right now, wanting a 6speed or change compensator?...... 2 year unlimited mileage warranty
I still need to run into u someday to check out your 121. That sounds like the way to go. I just don't want to do it twice. Want big. More than I need. And only want to buy it one time. Pulling it apart and screwing with it I can handle ever now and than. I want something that will scare the living ..... Out of me. That ain't easy!!!!!
If you want stupid power then a big cube engine with a turbo or another option is buy a 140" and have Ultima specialist John Sachs port the heads, bump the compression, jump the cam up, John has been coming up with engines that stand out in the dyno forums with Twinkie engines that is applauded by the numbers people and always a secret cam.
Attached John's email and a straight shooter that gets to the point, has always returned my emails and phone calls. John had a customer put a 113" Ultima on another forums updated dyno section that hit 139 hp. send him a email and he will be honest of your desires. Check out some older numbers on the Nightrider dyno section plus a turbo charged Sportster in the 160 hp range, Johns name will present
dynalee@bellsouth.net
