Oil on Fins, 99 FLSTC
I have not posted here in a while, but have a question. I was out on a ride today and a buddy noticed the oil on the fins, left side of the engine. His wife said she thinks it has been there a while. I recently (A few weeks ago) had the forks resealed because they were leaking. I detailed the bike last week so I doubt I missed this. I don't see any oil forward of that point, and cant really see where it is coming from. Any Ideas? On a side note, I am in South Carolina, and it was VERY HOT today, and we got stuck at SEVERAL stop lights. Any input is appreciated. Pictures are attached.
I thought I had an oil leak in my cam cover this past spring. It tuned out it was fork oil form a blown fork seal. You won't believe where drops of fork oil can end up. In my case, it was hitting the right side motor case, going down underneath the motor, then climbing up the back of the motor and wetting the rear motor mount.
I suspect that's what you have. Clean it up and keep an eye on it to see if it comes back.
Received 4,317 Likes
Ok, I posted this on a facebook Motorcycle forum I belong to as well. One sugestion was to check the exhaust bolts where it mounts to the front of the engine. I was told it can get some blow by when the engine is very hot if the bolts are loose. The lower one was loose. I cleaned it up as best I could (still have a stain) and will keep an eye on it. The oil was right in line with the exhaust, plus I ran a rag over the front of the rocker box and didnt really get any oily residue, so I dont think that is it. Plus I dont have an Allen wrench that is short enough to fit in there with the tank on, so I cant really check those properly. Anyway I will keep you guys informed on what else I found. Any suggestions on getting the stains off?
On a side note, it really was not a leak, but more of some blow by. Like I said, it was VERY hot yesterday and I was stuck in a lot of traffic in Columbia SC, and hit a lot of stop lights.
ericdiver
09-30-2008 10:49 PM
