Is there a trick to getting the fork caps off a wideglide?
Am not talking about the top tree nuts I am referring to the actual fork tube caps. I took the tubes out of the tree and I had the whole fork tube in my bench top vise with rubber jaws and still could not get enough force to unscrew the damn things. I am trying to change out fork tubes and this is holding me up. The manual just says to unscrew them. I am using a big wrench as it only has two flats and I don't think a socket would fit there. I don't think you can heat them either without melting the oring that is in there. Any suggestions
Received 4,317 Likes
I'm with THC on this. Can't think of a way it would help. Called a HD tech I know for grins and asked him what he would do. He said he has a Strap Wrench he uses. I'll try to get a pic.
He mentioned heat can distort the finish. that would be a Last Resort.
WP
http://www.harborfreight.com/catalog...q=strap+wrench
This is a real cheap example but should get the idea across.
Have seen better strap wrenches at Home Depot and such places.
WP
