New Clutch, no lever tension
Try this before you take the trans cover off, might save you some unnecessary work.
Remove the plate and adjustment bolt assy from the clutch, take something like a small wooden dowel, push on the pushrod and pull the clutch lever, if it moves in and out, I think a min of .080" with the lever, the ball ramp assy is OK, and look at the spring/pressure plate area.
I didn't disassemble the ramp or even take that side of the trans. I'm going to run to the stealership and pick up a new side cover gasket on my home and take it apart. This job has taught me to order gaskets and such on line. I can't believe the money I could have saved by ordering them on-line.
this is a great suggestion I will certainly try it. I must have missed it when posted. thanks schex
