Carb questions
Received 4,317 Likes
+1 on getting the Factory Service Manual.
It will be way more helpful than the Clymer.
Originally Posted by Tee⋁13224189
Yup. And welcome to the bestest forum on the board! Keep the Clymers but get the FSM for sure. Carefully drill out the wax, mud or whatever is over the mixture screw, 7/16 drill bit about an inch into the cover.
Welcome aboard,
Tom
Welcome aboard,
Tom
Your bike is what is referred to as a "bottom breather." The breather is at the bottom, towards the middle from the oil pump, as God intended it to be. Yes, the bolts are solid and not banjo because that's not the breather. Oh, and just to cover it for when you will eventually ask, yes, it is normal for oil to puke out the breather if you let the bike sit for several weeks to months.
Now, for your carb issue, first check for intake leaks. Next throw away that POS carb and put a S&S or a CV on there and you will solve the majority of your problems. Or if you insist on keeping the Keihin POS, rebuild it and you can get it to run poorly to fair (if you're really good.)
Welcome
Your particular problem could have many carb. related causes but i would advise you to rebuild the entire carb.
Google to find many HD cv carb. sites with parts and info.
The whole deal will cost you less than $100.00 bucks including shipping to your door if you do it yourself.
