Evo 89" Engine
Evo 89" Engine
1997 HD cases and cylinders, S&S 4 5/8 flywheel, S&S pistons, John Sachs ported HD heads that had aftermarket valves and springs for 625 lift installed, W6H Woods cam that is quiet, TP engineering oil pump supplies oil to crank at idle, Mikuni 45 tuned to the engine with a SE air cleaner and filter, also have a reworked CV carb tuned to the engine if a CV fan. Bolt in and run engine. $2600
The S&S Flywheel is notched for EFI if someone likes the stock HD MM system
