Mark this thread as Unsold
Jims 6-Speed Overdrive Transmission
Jims 6-Speed Overdrive gear set Part #8085
This Retails new for over $1,700.00
You can have it used today for $975.00 + Shipping or if your very close to SE WI we could meet.
Removed it from my FXR before I sold it. Put the stock 5 speed back in. Gear set has about 20K on it. Always ran Spectro Full synthetic gear oil 75w-140.
The only things not included with my sale, that is in the new kit, are the Main Bearing and Bearing Inner Race and gaskets.
Gear set worked great before removal, so no noise. I have the full instructions as well.
Here is the info from Jims catalog
6-SPEED OVERDRIVE TRANSMISSION SUPER KIT
Just like our popular 5-speed transmission super kits, our 6-speed kit is made with the same aerospace quality steel and precision machining. This kit is carefully assembled and ready to slip into your transmission case without removing it from your motorcycle.
JIMS® is proud to offer 6-speed overdrive transmission gears made in the U.S.A. by JIMS®. Imagine riding down the road at 75 MPH in 5th gear and by shifting into6th you reduce your engine RPM by almost 500 RPM.'s. It's possible to have
this option with the strength and reliability of JIMSĀ® quality gears and shafts. All gears are standard width for performance and strength, with first gear being close ratio 2.94, and the last four being the same ratio as a stock 5-speed. 6th gear goes to .86:1 overdrive.
Use as a complete gear set.
All kits incorporate JIMS® PRECISION CUT gears.
Kit number #8085 for Big Twins 1990-1999 and 1999-2000 FLHT, FXD
Gear . . . .Ratio
1 . . . . . .2.94
2 . . . . . .2.21
3 . . . . . .1.57
4 . . . . . .1.23
5 . . . . . .1.00
6 . . . . . .0.86:1
(Overdrive)
Gear . . . .Ratio
1 . . . . . .2.94
2 . . . . . .2.21
3 . . . . . .1.57
4 . . . . . .1.23
5 . . . . . .1.00
6 . . . . . .0.86:1
(Overdrive)
kopr2020
06-03-2011 10:57 PM
kopr2020
Evo Era Parts
06-03-2011 10:54 PM
