Baffle-less D&D fat cats
I have switched from the standard louvered baffle to the performance wrapped baffle and its definitely louder, so no baffle will for sure be much louder than what you have now.
You will probably loose some performance out of it due to lack of back pressure. D&D makes hell of a good pipe and they designed/flowed them with baffles, so I wouldn't get rid of them just for sound.
Why not remove the baffle, remove the insulation wrap and re-install that baffle. With the wrap removed, you essentially have their loudest baffle and tuned for the best overall performance. I've ran the perforated baffle before (without wrapping) and I quickly installed the wrapped perforated baffle. I do imagine it will be louder without a baffle of any kind. Afterall, it is called a baffle. If the perforated baffle isn't loud enough I would take a moment, go to the yellow pages and find yourself a doctor to give you a hearing test.
