DK custom thunder torque inserts ???
I just ordered a set and it says to use the existing holes where the baffles were bolted in. My question is that on my Samson street sweepers, the baffle holes are about 10" down inside the pipe, is there a trick to getting them in there or will I need to drill a hole closer to the end to install them.
Thanks
Thanks
If you have no hole at the end of your pipe, then you can drill a ⅜” hole in the bottom of your pipe, 1/2” - 2” from the end.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
I figured but I have been amazed of what people have come up with to do things. I may try to fish it thru with safety wire like when you have to replace your seat bolt on the underside of your fender.
