Sponsored by: Jekill and Hyde
Do I Need Adjustable Pushrods?
Old 04-25-2007, 06:30 PM
Sidehack's Avatar
Sidehack
Sidehack is offline
Default Do I Need Adjustable Pushrods?
I understand one advantage of adjustable pushrods is being able to change cams without removing the heads but I will have the heads off to install a 95 inch kit and will at the same time be changing cams (.510" lift). I've run this combo before and it's all I'll ever want so, if I never plan to change cams again,is there any other advantage to the pushrods?
Old 04-25-2007, 08:35 PM
JLOCKHART29's Avatar
JLOCKHART29
JLOCKHART29 is offline
Default RE: Do I Need Adjustable Pushrods?
A 1 size fits all ability and the easy cam change is the only advantage to adjustables. Disadvantage is wt. and possibility of coming loose. As long as you can find a rod to fit the 510 you will be fine. I'm sure S&S makes one.
dawg's Avatar
dawg
dawg is offline
Received 2,958 Likes on 1,712 Posts
non adjustablepushrods will be fine if you are taking off the heads anyway.
ext1bab
2014-2023 Touring Models
12-23-2016 03:47 PM
HD Pilot
35
09-22-2014 09:04 AM
tbyji2
12-07-2013 05:15 PM
Mike in Oregon
01-31-2011 09:19 PM
O5HOG
11-15-2005 11:04 AM
Quick Reply: Do I Need Adjustable Pushrods?
