Code P0134? oxygen sensor high/open front
P0134 oxygen sensor high/open front. Getting the check engine light code after front pipe came loose. Was riding home from work the other day 40miles. About half way I notice lots of popping/ back firing than usual. Got home seen front pipe came loose. Bolts where gone. Had to replace the studs from wear of the flange rubbing. After getting the job done I cranked it up and check engine light comes on. I have the v&h fuel pack which tells you the error codes. I delete the code and pops back up. Checked the sensor & look ok. Any ideas?
