Sponsored by: Jekill and Hyde
Reuse Gasket??
Old 07-30-2015, 01:30 PM
1BRAVO9's Avatar
1BRAVO9
1BRAVO9 is offline
Originally Posted by galaxyfe
Don't disagree; just asking. $10 is $10 that could be spent elsewhere if it's totally not worth it though. Many things are like that.
I understand your point and $10 is $10 to me it is worth $10 knowing that I won't have to go through the hassle of pulling the exhaust back off if the old seals don't work. But again, that's just me.
Old 07-30-2015, 02:47 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
There are very few other items on a HD that are $10 or less other than an occasional fastener or washer.
Old 07-30-2015, 10:22 PM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
No reference or recommendation in regards to that gasket in the paperwork that came with the pipes.
Old 07-31-2015, 02:43 AM
jackafrica's Avatar
jackafrica
jackafrica is offline
When you carefully remove the original exhaust, provided you don't disturb the original gasket by squashing or deforming (they are soft) it should be fine to use one more time, given the age of the bike/gaskets.
Follow the instructions diligently, if there aren't any and you have access to a factory manual, do it the MoCo way. They can leak otherwise.
You should have no difficulty, enjoy working on your ride.
There's genuine satisfaction in successful DIY.
Old 07-31-2015, 02:53 AM
jackafrica's Avatar
jackafrica
Heck, there's shiploads of bits under a tenner.
I seriously applaud the MoCo for making replacement bits under that threshold to encourage owners to replace parts, preventing failures. Works for me.
Gaskets especially, generally cheaper than aftermarket and better quality.
Fasteners with thread locker on them are usually cheaper than the bottle of thread locker.
I recall when fasteners on new bikes were poorly finished, back in the 80's and 90's, but that's another time.
Old 08-06-2015, 10:28 AM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
So I did my pipes, and I didn't even see anything that even looked like a gasket...there was nothing there!?!?! So I put the new pipes on and not even the slightest hint of an exhaust leak.
Old 08-06-2015, 11:01 AM
nevil's Avatar
nevil
nevil is offline
The gaskets crush into the head and are flush, so when coated with even a little soot they blend in. You need a pick tool to get them out most of the time. But if they aren't leaking you're good.
NWGlide
2014-2023 Touring Models
14
09-20-2014 06:22 PM
hfp3030
05-01-2012 09:43 AM
snooper0069
04-12-2009 01:00 PM
jimd4au
08-08-2008 06:57 PM
smac101
08-31-2007 02:23 PM
Quick Reply: Reuse Gasket??
