Sponsored by: Jekill and Hyde
O2 sensor bung location
Old 08-01-2015, 05:58 PM
johnnyt5646's Avatar
johnnyt5646
johnnyt5646 is offline
6th Gear
Default O2 sensor bung location
I have a 2009 street glide with the 18mm O2 sensors. I have Fabricated my own exhaust. I would like to finish it tomorrow. I just need to weld up the O2 Sensor bungs. i need to know how far from the head should the O2 sensor be. Because of the design of the exhaust it will be hard to get them more than 4" from the head. I know they need to have a 10* angle going with the flow of exhaust but what is the minimum and maximum distance.
Thanks
John
Old 03-19-2017, 12:27 AM
knife_edge's Avatar
knife_edge
knife_edge is offline
I would like to know the answer your question myself. It is very hard to get an answer on this topic.
Old 03-19-2017, 07:26 AM
Eastcoast Jim's Avatar
Eastcoast Jim
Eastcoast Jim is offline
You want them close to the head - 4" is ideal - you can go to 6 maybe 8 if you need to - Eastcoast Jim
Old 03-19-2017, 08:42 AM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is offline
Actually the small sensors are heated and are designed to be able to be further down the pipe. Too close to the head can cause the sensor to be exposed to too much heat. The other side of the equation is understanding that the HD ecm looks at the sensor read at only certain moments in time (crankshaft rotation due to cam events )so the location can be tied to the distance down the pipe. If you're in the ballpark of where an OE sensor would be for the same style system you're most likely all good. You will also be ok in other locations, but that is the safest answer if you are doing this yourself.
The other thing to know is that if there is a part where the system comes together, the sensors must be far enough up the pipe so they do not cross-read. When that occurs, the ecm can't control fuel properly and there are a host of driveability issues.
Old 03-20-2017, 08:20 AM
knife_edge's Avatar
knife_edge
I found a couple photos online of placements for those 02 bungs thank you for the person who actually took the photos.
gtwalker1969
04-13-2018 09:09 AM
PRODUCTofNJ
09-22-2014 08:30 PM
marknett
02-06-2013 06:20 PM
Bowtieman31
01-09-2008 11:12 PM
diamondheadglide
12-14-2007 07:07 AM
Quick Reply: O2 sensor bung location
